The part in question is located under the hood on the drivers side, behind the mass airflow sensor/wiring connections. It also has a hose coming out and going to the pcv valve on the valve cover. At first noticed it clicking randomly about 40- 50 times a minuite. found that bracket is not bolted down, bolted unit down. Unit still clicking, mayby not as often, but close. I checked out wiring and ground, can anyone tell me what this part is called and what problems it can cause if it goes out?
Jan 15, 2009 at 7:36 AM
