Transmission problem
2000 Pontiac Montana 6 cyl Front Wheel Drive Automatic 177k miles
When O2 sensor fails, does it affect on transmission? i noticed with my 2000 montana that since the O2 sensor failed a few months ago, the shifting on my transmission is slipping after 2o mins drive or when the engine starts to heat.shifting is ok at the start or when i left home but after 15-20 mins drive i can feel that tranny is slipping every shifting of gears.i'm a bit hesitant to send it to mechanic to fix or change the o2 sensor because it might be useless if the tranny will fail or damaged already.if it is, is the additives like lucas transmission fix helps?some say it's effective but most says it's not.thanks
Nov 15, 2009 at 3:11 AM
