2000 Pontiac Montana crankshaft pulley
2000 PONTIAC MONTANA
EMPIRE490
Engine Mechanical problem
2000 Pontiac Montana Two Wheel Drive Automatic 147000 miles
My serpitine belt came off.I put on new one and when I started it up the belt came off.I noticed when I went to put belt back on that the crankshaft pulley is not inline with the rest of the pullies alt,aipower steering.What would cause this to happen?
May 12, 2009 at 8:07 PM
KEITHANDBEV
I have just experienced the same thing today...........any ideas anybody
Jan 24, 2012 at 8:27 AM
You crankshaft pulley could be loose try torquing it to specs and inspect the other pulleys double check belt tracking/alignment
Jan 24, 2012 at 9:06 AM
KEITHANDBEV
In another forum I found many Montana's where the Harmonic Balancer has come apart which is causing the pully to be 1/2" out of alignement so I will check this now..........thanks everybody.
Jan 24, 2012 at 9:12 AM
MATTF6
What were the results? I have a similar issue with the same year/make/model.
Thanks for any info.
Aug 16, 2013 at 6:26 PM
DKROESE
I had the same problem and the harmonic balancer (102K miles)had actually started to separate and caused the pulley to move forward. Oriellys to my surprise had it in stock so I suppose it is a common problem. At the same time I found everyone of the idlers/bearings(there are a few) were wore out so I replaced them
Aug 17, 2013 at 11:17 AM
