2000 Pontiac Montana Blinkers not working
2000 PONTIAC MONTANA
50,000 MILES • 6 CYL • FWD • AUTOMATIC
MTCONACHEN
The Blinkers will not work. The hazzards work fine with the exception of the drivers rear is very faint. The brights work ok and so do the wipers.
Checked the main ground and it is connected.
Tried to turn the stearing wheel as the blinker switch was on and that made no difference either way.
Not sure what else to check!
Feb 13, 2008 at 7:58 PM
BMRFIXIT
  • 19,053 POSTS
[quote:35fad4a582="mtconachen"]Other Category problem
2000 Pontiac Montana 6 cyl Front Wheel Drive Automatic 50000 miles
Not sure what else to check![/quote:35fad4a582]
did you check the flasher
check ground at the bulbs
Feb 13, 2008 at 8:03 PM
MTCONACHEN
'Where is the flasher?
Feb 13, 2008 at 8:07 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e7164fd5aa="mtconachen"]'Where is the flasher?[/quote:e7164fd5aa]
Below left side of dash left side base of steering column
Feb 14, 2008 at 8:40 PM
