1999 Pontiac Montana head gasket torque setting
1999 PONTIAC MONTANA
290,000 MILES • 6 CYL • FWD • AUTOMATIC
CUDDLES327
Hi again.could you tell me the correct head bolt sequence and torque setting.I have it all apart now i will clean up all the antifreeze accumulated in each cylinder,install new gaskets and be on my merry way.Thanks
Apr 15, 2009 at 3:35 PM
BLACKOP555
  • 10,386 POSTS
start at the middle bolts and work your way to the outer ones on the left side. then center to the right.
torque to 350 inch lbs.
Apr 18, 2009 at 8:34 AM
