1999 Pontiac Montana
1999 PONTIAC MONTANA
PUTMANPOWER
Other Category problem
1999 Pontiac Montana V6 Two Wheel Drive Automatic 120000 miles
where is the fuel pump reset switch on a 1999 pontiac montana. I ran out of gas and now it will not start after putting gas in it
Dec 9, 2007 at 12:46 AM
SERVICE WRITER
  • 9,123 POSTS
There is no reset switch. If you think it is a fuel problem, you can spray carb cleaner or some starting fluid in the throttle body then crank it to see if it is indeed a fuel problem. It may be ironic that your fuel was very low and the source of the problem is not a low fuel situation.
Dec 9, 2007 at 7:18 AM
