1991 Pontiac le mans
1991 PONTIAC LEMANS
EKIM22555
My fuel pump runs after car is off, and keeps blowing fuses left and right. I would like to check the fuel pump relay but am unsure where it is! Does any one have any suggestions for this problem?
Jul 21, 2007 at 9:00 PM
MR.COUGAR
i had recently bought a new relay as well and had the same problem i didnt know were it was. you have to basically lay on the ground and look under neath the steering weel behind the fuse block. it will be the relay that is plugged into the blue port !
Jul 27, 2008 at 3:55 PM
