1969 Pontiac GTO Brake Lights
1969 PONTIAC GTO
94,000 MILES • V8 • 2WD • MANUAL
GHULL1954
My brake lights on my 1969 GTO are not working. This happened several months age. I replaced a flasher unit and the lights worked. Now the brake lights are out again. All of my park lights, turn signals and flashers work. I even changed the brake light switch. Ideas?
Jun 13, 2009 at 10:36 PM
BUDDYCRAIGG
  • 2,262 POSTS
I have this problem on my 67 all the time.
the sockets are not grounding to the housings good enough.
Jun 30, 2009 at 11:09 PM
DGK
  • 10 POSTS
You may have a bad turn signal switch. Check for power at the brake light socket with a test light that is well grounded. If you don't have power there the problem is either in the wiring or the turn signak switch.
Mar 15, 2010 at 8:10 PM
