Suspected leaking a/c inside car
PONTIAC GRAND PRIX
EPF
The front passenger side floor board is soaking wet. I've only had the car for 4 weeks, so I do not know the history of the vehicle. I suspect that the a/c is not draining outside the body, but has found its way into the cab of my car.
Specs:
2004 Pontiac Grand Prix GT1
34k miles
Automatic
3.8L V6
May 13, 2007 at 9:55 AM
MIKE H R
  • 3,094 POSTS
is the floor wet with water is there anti freeze in it? if there is antifreeze then you woul have a heater core leak.
May 13, 2007 at 12:29 PM
SERVICE WRITER
  • 9,123 POSTS
I ran into this on a car similiar, but I don't recall if it was water leakage or if it was the drain plugged. Have definitley seen drains plugged and doing as you describe.
May 13, 2007 at 1:11 PM
SERVICE WRITER
  • 9,123 POSTS
The 04 Grand Am we had in the shop had a leak into the trunk. Although there was a tsb for the trunk leak it was the rear window.
There is another tsb on your condition as far as water in the passsenger floor board area. IT eminates from the drain from the sunroof. With out having the car, I'm not sure the best way to get to the heater duct that may be filling up from A/C condinsation. In our area we have a guy that comes around to do water leaks, as that is all he does...and good at it!
May 14, 2007 at 9:34 PM
