93 grand prix battery drain
1993 PONTIAC GRAND PRIX
LEIST
I have a 93 grand prix and have changed the alternator and starter/celinoid. no lights left on . Help! What else could be doing this
Jun 22, 2007 at 7:44 PM
HEATH73
Unhook the battery ground, and hook in a test light between the battery post and the cable. The light should be on if you have a draw on the battery. If you do, go to the fuse panel and start puling fuses, one at a time, and then reinstalling them. When the light goes out, search that circuit for the draw. Happy hunting!!!
Jun 26, 2007 at 9:51 PM
SC1 RACING
  • 117 POSTS
if you know how to use a multi meter you can messure across the fuse untill you find the biggest draw. then you can narrow your search dont to the circuts in the fuse. check batt cables and all cables and connections for corrosion. corrosion kills batts
Jun 27, 2007 at 10:26 AM
