Does any one know what the voltage should be for the crank sensor on a 93 grand prix 3.1?
runs for a bit then dies, after a while it starts again. If you let it run for about ten minutes and shut it off, it wont start unless you press the gas a little bit.
I changed the EGR, throttle positions censor, IAR valve, checked for vacume leeks???????????
Oct 16, 2007 at 3:23 PM
