2007 Pontiac Grand Prix heat and air conditioning is not bl
2007 PONTIAC GRAND PRIX
TONYA1160
Heater problem
2007 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
The blower is blowing intermidiately. Most times now it does not blow but once in a while it will start blowing like nothing is wrong. I have checked the fuses under the hood and they all seem to be fine. Where is the blower moter located? Could it be a loose wire? Any suggestions would be very helpfull.
Thank you
Jan 27, 2010 at 5:32 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect the blower motor is defective and need to be replaced
located on passenger side
unplug wiring connector start engine ,place fan switch at high
check for power and ground at the connector plug if have both remove and replace the motor
Jan 28, 2010 at 9:10 PM
