2007 Pontiac Grand Prix
2007 PONTIAC GRAND PRIX
15,000 MILES • 6 CYL • FWD • AUTOMATIC
IBDUHONE
the cruise control just stop working!! I checked the cruise sw. (2 Amp) and it looks ok. Everything on the left smartstick work fine.Is there another fuse on connector I should be looking for. It is still under warranty, and I would like to attempt to fix it if possible, so I wouldn"t tie up a day for the dealership, especially if it is a simple fix. Thank you for your advice. Jim
Feb 14, 2009 at 1:02 PM
RACEFAN966
  • 5,029 POSTS
Ok if it under warranty and you attempt to fix it yourself and make any mistakes then you no longer have a warranty. I would use the warranty and have them give you a loaner car while they have your car.
Feb 14, 2009 at 1:10 PM
IBDUHONE
thank you. i will do as you suggested.
Feb 14, 2009 at 1:37 PM
RACEFAN966
  • 5,029 POSTS
No problem I hate to see something happen to void your warranty. I did check to see if there were any TSB's or anything and I found nothing.
Feb 14, 2009 at 1:43 PM
