2004 Pontiac Grand Prix sunroof
2004 PONTIAC GRAND PRIX
CHARLES STOOPS
Interior problem
2004 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
leaking sunroof maybe drains stopped up but i dont know where they are
Dec 28, 2008 at 2:45 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please give me your engine size in liter and the 8th digit of your VIN.
Based off of what you have said, there is a Technical Service Bulletin out on this. I have attached it for your review.
Body/Interior - Headliner is Wet Around Sunroof
Notes
Bulletin No.: 04-08-57-007B
Date: December 06, 2005
TECHNICAL
Subject:
Headliner Wet Around Sun Roof (Modify Drain Hose)
Models:
2004-2005 Chevrolet Monte Carlo, Impala
2004-2005 Pontiac Grand Prix
Supercede:
This bulletin is being revised to add leak repair verification steps. Please discard Corporate Bulletin Number 04-08-57-007A (Section 08 - Body and Accessories).
Condition
Some customers may comment that the headliner is wet or that water is dripping out of the overhead reading lamp.
Cause
Both front corners of the sunroof have a drain hose running down the A pillar and end up down at the floor behind the lower kick pad on the left or right side. The end of the sunroof drain hoses may be laying flat against the foam at the base of the "A" pillar. This may cause a partially plugged drain hose. During a heavy rain, water that should be draining away may back up and overflow into the headliner at the front of the vehicle.
Correction
1. Remove the lower right hand and left hand lower kick pad.
2. After locating the hose, cut the end of the hose into a point.
3. Verify that the lower "A" pillar drains are open by pouring a cup of water in the bottom of the "A" pillar.
4. Check the drain hoses from the sunroof down to the bottom of the "A" pillar by using shop air.
5. Reinstall the kick pad.
Dec 28, 2008 at 3:15 PM
IMPALASS
  • 3,112 POSTS
Hello –
I was reviewing previous posts and wanted to provide you with this info. Looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
08089
06/13/2008
Campaign - Analog OnStar(R) Deactivation
05018
03/08/2005
Recall - Electronic Throttle Control Pedal Replacement
NHTSA05V046000
02/04/2005
Recall 05V046000: Accelerator Pedal Replacement
04055
08/16/2004
Recall - Front Frame/Rear Body Mount Fracture
NHTSA04V287000
06/01/2004
Recall 04V287000: Caliper Mounting Bolt Torque
NHTSA04V299000
06/01/2004
Recall 04V299000: Potential Steering Shaft Separation
04049
06/01/2004
Recall - Front Brake Caliper Tightening Torque
03045
08/01/2003
Recall - Right Rear Brake Hose Torque
Dec 30, 2008 at 9:10 PM
