2004 Pontiac Grand Prix Engine burning oil
2004 PONTIAC GRAND PRIX
81,252 MILES • 6 CYL • FWD • AUTOMATIC
FRANK MONACO
I change my oil every 3000 miles without burning or losing any oil. After my last oil change, the information center came on at 2500 miles and said low oil warning. I checked the dip stick and found I was 1 1/2 quarts low. I checked for leaks and found none. I filled to the proper level and checked after each fill up. I am getting 900 miles to a quart. What could be the cause of this problem.
Feb 17, 2010 at 8:33 PM
MMPRINCE4000
  • 8,548 POSTS
If it is not leaking it, then it is burning it.
Start by checking the PCV valve, make sure it "rattles" when you remove and shake it.
If OK, then start with compression test.
If you notice blue smoke on startup, then valve stem seals.
Feb 18, 2010 at 6:33 AM
FRANK MONACO
Thank you for your imput, I have GM extended bumper to bumper warantee. Will take car to dealer. Just wanted to know in advance if I was getting a BS story. If you like, I will follow up with the outcome. Thanks again.
Sincerely,
Frank Monaco
Feb 18, 2010 at 11:18 PM
MMPRINCE4000
  • 8,548 POSTS
Feedback is always welcome, please let us know what the fix turns out to be.
Feb 20, 2010 at 8:16 AM
