2003 Pontiac Grand Prix Fuel tank overflow when filling
2003 PONTIAC GRAND PRIX
54,000 MILES • 6 CYL • FWD • AUTOMATIC
PRIMO48
None of the listed categories seem to fit my problem. I had my fuel pump replaced today and when I went to fill the gas tank I found it was taking an unusually high amount of fuel to fill. (I later checked the owners manual and GM states the capacity is 17.2 gallons) When it reached just over 19 gallons I stopped and then noticed there was a stream of fluid flowing from under the vehicle. Looking up from underneath the rear of vehicle I could see gas pouring down the sides of the tank. Could the repair shop have affected a float or gas level sensor when replacing the fuel pump thereby disabling the device or action that would help prevent this type of incident from happening? I am the original owner for 6 1/2 years and have never had this happen.
Thank you
Jun 27, 2009 at 10:18 PM
MERLIN2021
  • 17,250 POSTS
Go back to the shop, the tank gasket must not be seated right, it is installed with the new pump. or a hose is loose. For saftey reasons, I would have them come and tow it back.
Jun 28, 2009 at 5:57 AM
