My 2002 grand prix has been diagnosed with a bad throttle body,the main problem it has right now is it will not start, not even making a connection to turn over, to me this problem sounds more like it is in the starter or ignition. when you turn the key it does not even click. I have had problems with the gas pedal sticking once it is first started, but it has always been fine after that. occasionally the problem of not making contact has happened before, but usually within a few minutes it starts and runs fine. is it possible that the throttle body is causing this problem? - did not match any documents.
Feb 28, 2009 at 3:15 PM
