2002 Pontiac Grand Prix humming/generator noise at 30mph
2002 PONTIAC GRAND PRIX
63,000 MILES • 6 CYL • FWD • AUTOMATIC
BUDDYSKING
Car makes a humming noise at 30 mph and up, but upon deceleration still hums below 30mph. All fluids great, but P.steering little low. Filled up and still noise persists. Just had new tires and brakes few months ago, problem started last week. Any suggestions? Hum does not get louder or decrease when hard steering and does not appear when stopped and revving engine at all. Also stays on when coastingdriving in N, D, and low gears. THANKS!!!!
May 2, 2009 at 11:03 PM
MERLIN2021
  • 17,250 POSTS
You sure it not a front hub bearing? Try quickly turning the wheel left and right while it's making the noise, if it increases and decreases in intensity, it probably is. If it increases as you turn left, the right bearing is bad, and vice versa.
May 3, 2009 at 8:56 AM
BUDDYSKING
The noise does not seem to come or go or is dependent on any steering made. Any other suggestions or maybe rotating the new tires??? thanks matt
May 3, 2009 at 8:47 PM
MERLIN2021
  • 17,250 POSTS
If it seems to be comming from the engine itself, check the serpentine belt and the idler, tensioner alt, PS, and a/c pulleys for any binding by turning them by hand.
May 5, 2009 at 1:31 PM
BUDDYSKING
will do! Will let you know! thanks
May 5, 2009 at 8:53 PM
