2001 Pontiac Grand Prix head gasket repair
2001 PONTIAC GRAND PRIX
TRENLI
  • 5 POSTS
Engine Cooling problem
2001 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
I am trying to change the head gasket on my 2001 pontiac grandprix and are having trouble removing the mounting bracket that is on the left side of the motor. I have removed all of the bolts but I cannot lift the mounting bracket enough off of the head bolt to move the bracket out of the way. Not sure what else to do... because I need to move that mounting bracket out of the way in order to get to and change the head gasket!!!!!
Sep 12, 2010 at 3:52 PM
WRENCHTECH
  • 20,761 POSTS
What engine do you have and what bracket are you referring to.
Sep 12, 2010 at 4:33 PM
TRENLI
  • 5 POSTS
a 3.1 liter engine
I'm not exactly sure which type of motor mount bracket it is but its a c type bracket that sits over the intake manifold
Sep 12, 2010 at 4:45 PM
WRENCHTECH
  • 20,761 POSTS
There aren't any head bolts in that area so I have no idea what your talking about.
A picture would help.
Sep 12, 2010 at 4:47 PM
TRENLI
  • 5 POSTS
https://www.2carpros.com/forum/automotive_pictures/572126_downsized_0912001500a_3.jpg
the c type bracket wraps around the exhaust manifold and the bracket extends down. it is on the #5 headbolt accordning to the sequence from the hanes book.
Sep 12, 2010 at 5:16 PM
WRENCHTECH
  • 20,761 POSTS
That bolt has to be removed.
It's either a Torx or an Allen socket.
Sep 12, 2010 at 5:18 PM
TRENLI
  • 5 POSTS
that bolt is the head bolt and i cant get to it without removing the bracket 1st.i cant take off the heat shield or the exhaust manifold either. the bracket sits on that bolt but when i go to pull up on the bracket it comes up but because it goes aroung the manifold it hits it. preventing me from taking it off the #5 head bolt.am going to send a few more pics. maybe that will help.the 1st 1` is of the bracket pulled up not wont come off the #5 head bolt, the 2nd 1 is of the what the bolt looks like under the bracket,and the 3rd is of where i took off 1 of the bolts to the bracket,
Sep 12, 2010 at 5:55 PM
WORM7986
There are three bolts holding that bracket in place. One is right where you can see it the other two are on the A/C compressor. Remove them two bolts in A/C compressor along with motor mount bracket bolt and it will come free:D
Feb 20, 2012 at 4:44 PM
WRENCHTECH
  • 20,761 POSTS
Sept 2010. I think he has it resolved by now
Feb 20, 2012 at 5:07 PM
