2001 Pontiac Grand Prix engine has no spark
2001 PONTIAC GRAND PRIX
97,185 MILES • 6 CYL • FWD • AUTOMATIC
CKAFRIEND
My 2001 Grand Prix has no spark for the engine to start. I had the coils and the ignition module tested and there was no problems there. The plugs and wires are new. I replaced the ECM and the Crank sensor, but still have nothing. What else could cause this problem?
Mar 26, 2009 at 10:42 AM
JDL
  • 16,098 POSTS
Hello, I'd have to do my own testing,as far as the wiring circuits. I would'nt replace anything without testing the wiring circuits.
What is the litre size of your vehicle? Are you missing anything besides spark, is there an injector pulse, during cranking? Any codes?
Mar 26, 2009 at 11:00 AM
CKAFRIEND
the engine is a 3.1L. I don't know what you mean by injector pulse, but there were no trouble codes when I used the scanner to check them.
Mar 26, 2009 at 11:31 AM
JDL
  • 16,098 POSTS
The 3.1 shows to have two separate crank sensors. I'm not sure which one you replaced? The one I usually think of first is the one that plugs into the ignition module. I can't tell you that sensor is faulty, I'd have to look at it.
If you do a lot of cranking and the injectors are pulsing, you may have flooded the engine, check the plugs.
You could use a noid lite on the injector plug, crank the engine, if the noid lite pulses, there is voltage and ground at the injector/s. You could probably use an led testlite to check for pulse.
Mar 26, 2009 at 12:36 PM
CKAFRIEND
I'll give that a try tomorrow then...Thanks a lot!
Mar 26, 2009 at 3:13 PM
