2000 Pontiac Grand Prix Windshield Wiper fluid not coming o
2000 PONTIAC GRAND PRIX
KAIJAI01
Interior problem
2000 Pontiac Grand Prix 6 cyl Wheel Drive Type unknown Automatic 101000 miles
The fluid no longer comes out of the wipers as it should. I thought they needed replacing but after that was done, still nothing. I press the button and the wipers go back and forth as expected BUT the washer fluid doesn't come out. What could be wrong and is it something I can fix myself?
Thank you
Mar 5, 2008 at 1:15 PM
SERVICE WRITER
  • 9,123 POSTS
The fluid may be frozen in the linem or restricted.
Do you hear the pump run when the button is pressed? IF so
Disconnect the line and blow through it.
IF not check the fuse for the pump, and then for power to the pump.
Mar 5, 2008 at 1:27 PM
