i have recently fix my valve cover gasket only because my dealer diagnose it when i went for an oil change ,from a mechanic for about 700 dollars because my dealer will do it for about 900 dollars, but exactly 2 weeks after that i was on my way to milwaukee, 83 miles away, my car did something that i couldnt believe. i drove about 60 miles and i felt like when i press down the gas, my car wouldnt respond at the same time it will take about 3 sec follow with a loud acceleration noise, about 10 min after that, in the middle of a 4 lanes traffic, the gas pedal wouldnt respond at all anymore, and my car started slowing down, i managed to pull over and start braking but it shut off by itself before it came down to complete stop. i immediately open the hood, and i saw my coolant reservoir was boiling and the coolant was coming out from the top, and left a long trail behind it, i waited till it cooled down, and started my engine again, that when i heard some loud noises from the engine then it shut off by itself again. I had to towed it all the way back to the mechanic who fix my lower intake valve cover gasket which cost me about 300 dollars, and he took out the belt and the noise still persist, then the next day he said, i had some metal in my engine oil that it could be the camshaft or one or two bearing that are broken that he will fix it for 1700 dollars or i can buy an engine and it will be about the same price, or he can fix it for 700 dollars then it will only work for awhile, time for me to get rid of my car. Get rid of my car? 2 weeks ago this car was running fine, i have only done 2 oil changes so far since i bought it, and having heard this i just took my car from him and brought it home. I would like to know if any of this have anything to do with the lower intake valve cover gasket that i fix and what exactly went wrong with my car and if i should buy anything that the mechanic says, thanks
Aug 15, 2009 at 10:01 AM
