2000 Pontiac Grand Prix radiator
2000 PONTIAC GRAND PRIX
BLACKJACK21
Engine Cooling problem
2000 Pontiac Grand Prix 6 cyl Two Wheel Drive Manual
how to change
Nov 5, 2008 at 5:36 AM
MMPRINCE4000
  • 8,548 POSTS
Use the car repair manual link in this thread or get a Haynes manual.
Generally you drain coolant, remove any plastic covers on the radiator, remove fan connectors, fan assy, radiator hold down bolts/brackets, hoses, radiator.
Some cars require that you may have to remove the alt, or some other accessory, which is why you need a manual for reference.
Before you start, disconnect the negative battery cable.
Nov 5, 2008 at 8:22 AM
