2000 Pontiac Grand Prix Out of Idea's
2000 PONTIAC GRAND PRIX
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
AADJ0402
My wife and i went to town Car ran great . Got back in to leave again . Car wouldnt start Changed the fuel filter check the fuel pump all was well but car would still. Not start. Changed the thottle positioning sensor. Now car will start but go dead about 2 minutes later almost like its choking itself out. What now???
Mar 29, 2009 at 10:44 AM
MERLIN2021
  • 17,250 POSTS
Have you done a relearn on the pass-key?
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Mar 29, 2009 at 11:02 AM
AADJ0402
tryed that but no glory....The car only starts when i let it sit for about 1 hour then runs for about 2 minutes. If i try to start it without letting it sit. It wont start at all...
Mar 29, 2009 at 11:23 AM
MERLIN2021
  • 17,250 POSTS
You are at the point of needing to read any stored codes, even if you have to buy a scanner to do it. Post all codes that come up, and if you can all freeze frame data.
Mar 29, 2009 at 11:39 AM
