i change the cat converter. the exhaust glows red hot.
Aug 31, 2008 at 2:56 PM
BLACKOP555
CERTIFIED EXPERT
sounds like the vehicle is running very rich. take a look into that first
Aug 31, 2008 at 5:44 PM
BUDCREW
MEMBER
any ideas where to start ?
Sep 1, 2008 at 1:56 PM
BLACKOP555
CERTIFIED EXPERT
first where she glowing red hot?
when did this happen?
does it do it at idle or only after driving the car fast.
Sep 1, 2008 at 3:34 PM
BUDCREW
MEMBER
the wife drove to the bank.she said the floor of the car was hot. the old converter was glowing behind the converter. the new one glows converter back.car has a miss now
Sep 1, 2008 at 5:05 PM
BLACKOP555
CERTIFIED EXPERT
sounds like a lean issue, tell you what. take the vehicle to autozone and have the codes scanned and post them back here. see if somethings happenin.
Sep 1, 2008 at 5:48 PM
BUDCREW
MEMBER
the code po102
Sep 1, 2008 at 5:59 PM
BLACKOP555
CERTIFIED EXPERT
Mass Air Flow (MAF) Circuit Low Input is what it means.
and that can cause your problem..
try disconnecting and removing it then cleaning the sensors off on it with some qd contact cleaner. then hook it up again and see how it goes.
