i had my car in for an oil change. It sat outside overnight after the oil change. The outside temp was -22. I picked up the car. I had a 1/4 tank of gas. the car started at the repair shop. I drove it home live about 3 miles from the shop. I turned it off it was parked at a slight slope for 4 hours at -15 I went to start the car and it started then it died. I pushed it into the garage and added 6 gallond of gas and 1 pint of heat. I heated the garage to aboout 50 degrees for 5-6 hours and the car will start and then dies after about 30 seconds. In order to restart it I have to turn off the key. I have removed the battery. I'm not getting any service engine soon light message. do you think I need to replace the fuel filer or fuel pump. If so, where are these located?
Thanks
Anderson
Thanks
Anderson
Jan 18, 2009 at 10:29 AM
