2000 Pontiac Grand Prix Cooling fans dont work
2000 PONTIAC GRAND PRIX
HALNINO
Engine Cooling problem
2000 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
Neither of my 2 cooling fans work. I replaced the temp sensor and the thermostat. The AC / heater blower works fine.
Sep 13, 2009 at 11:50 AM
JDL
  • 16,098 POSTS
Did you check the fuses, I saw two? Use a testlite, the fuse circuits should be hot all the time. If you unplug the cts or turn on the ac, does the fan/s run?
The fuses and relay/s for the radiator fan/s should be in the power distribution center under the hood.
Sep 13, 2009 at 12:55 PM
