2000 Pontiac Grand Prix
2000 PONTIAC GRAND PRIX
194,000 MILES • 6 CYL • FWD • AUTOMATIC
JUSTIN55
how do i remove the hub bearing on the driver side to replace the rotors bolts
Mar 12, 2009 at 5:53 PM
MMPRINCE4000
  • 8,548 POSTS
The hub is bolted to knuckle, USUALLY with Torx bolts. Remove wheel, caliper, brake pads, bracket, rotor, dust shield.
There should be a larger hole in hub to access hub to knuckle bolts.
Be carefull removing the bolts if they are Torx heads, rent, buy an electric impact and MAKE SURE you use the correct torx bit.
Mar 13, 2009 at 8:16 AM
