1999 Pontiac Grand Prix what is the problem and how can I s
1999 PONTIAC GRAND PRIX
155,590 MILES • 6 CYL • FWD • AUTOMATIC
MAURICETHEONE27
I have roaring noises from the front right of the car, when I turn to the right and drive straight I hear it at a sertain speed up to 30 and above, but when I turn to the left. I don't hear anything, but the car drives smoove, the front right may shake when i get up to 60mph. I will rotate tires if possible
Jan 28, 2010 at 12:15 AM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Could also be an alignment contributing to problem.
Jan 28, 2010 at 8:21 AM
BABYLO
I just recently had the same problem but mine was usually if I was straight or turned left. I would say that if it only did that when you turn it is the bushings. Cost me about $250...Exspensive, but if you don't get it fixed, it is bad for your tires and brakes...Good luck to you!
Jan 29, 2010 at 1:19 PM
