Hello
Thanks for the donation
The owner's manual should come with a troubleshooting guide for the scanner.
Ensure that you are connecting it to the correct port. Make sure you are going by the steps per manual as well. Key must be in certain position of ignition.
If you feel it is not your scanner that has the issues, you can always go to a local part store such as AutoZone and have them use their scanner to see if it works on your vehicle. If so, then you will know it has something to do with your scanner and not the vehicle's computer.
The check engine light must be illuminated for the diagnostic scanner to work as well.
Hope this helps..
Thanks for using 2carpros.com!
Dec 24, 2008 at 12:42 AM
