I have to replace my right front spindle and I'm having trouble getting the hub. I have taken the axle nut off and the brake caliper and the 3 bolts behind the hub. I'm thinking these are the hub mount bolts... they bolt into the spindle/knuckle. I only found 3 but the manual says there are 4. Am I over looking a bolt? The 3 i found, 1 was located top center, 1 bottom right and one middle left. I'm being careful not to damage anything. That's why I'm asking. If there are only 3 bolts, what is an alternative way to remove the hub without using a puller? Thanks for the help.
Feb 21, 2009 at 4:47 PM
