when stepdaughter left last night a noise startred about 50 feet from house.when she came over this morning the noise was there again.after taking a ride we found the noise sterted when the a/c or defrost buttons were pushed.the noise is similar to a grind but not like brakes when they wear down.the tension pulley above the a/c pump,but not on the same belt,was replaced a month ago so i checked the pulleys before going on a ride and none were moveable.the belts are both good/brand new and proper tension.thank you for your help.
Oct 10, 2009 at 11:28 AM
