1998 Pontiac Grand Prix i just got work done too it
1998 PONTIAC GRAND PRIX
181,000 MILES • 6 CYL • FWD • AUTOMATIC
LINDA46
and i can fill every little bump in it.. its like the steer wheel moves when u hit a bump...and when starting it the car is idol too high cause it jumps up and down and turns off sometime...what can be doing that..
Mar 23, 2009 at 4:03 PM
MMPRINCE4000
  • 8,548 POSTS
What kind or work was done? You probably need an alignment for the steering problem.
A high idle is usually a vacuum leak, or an IAC (idle air control valve), remove and clean the IAC, get front end checked for an alignment issue
Mar 26, 2009 at 8:24 AM
