1998 Pontiac Grand Prix HEATER BLOWER MOTOR REPLACEMENT
1998 PONTIAC GRAND PRIX
11,000 MILES • 6 CYL • 2WD • AUTOMATIC
R DOWNEY
NEED TO KNOW BEST PROCEDURES TO REPLACE THE BLOWER MOTOR IN THIS CAR
THERE MAY BE ANOTHER RELATED PROBLEM
THE LOWER SPEEDS HAS NOT WORKED FOR A WHILE
Nov 22, 2008 at 7:14 AM
IMPALASS
  • 3,112 POSTS
Hello - I have attached the info you requested...you didn't specify which engine size so I went with a 3.8L VIN K....(the VIN is the 8th digit of your VIN number) I gave you the procedure on blower motor replacement. You most likely cause for the fan speed is the blower resistor is bad. I have also provided that for you.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture1_12.jpg
Blower Motor Notes Remove or Disconnect Battery ground negative cable. Right side instrument panel insulator. Blower motor cooling hose. Blower motor electrical connectors. Blower motor mounting screws. Blower motor. Install or Connect Blower motor and mounting screws. Tighten Screws to 20 N.m (14 lb. ft.) . Electrical connectors. Blower motor cooling hose. Right side instrument panel insulator. Battery ground negative cable. Blower Resister Remove or Disconnect Right side instrument panel insulator. Electrical connectors from blower motor resistor. Loosen (do not remove) both forward mounting screws. Blower motor resistor opening is slotted as access is extremely limited. Rearward mounting screw. Blower motor resistor. Important Care must be taken when removing the blower motor resistor. The resistor is a ceramic card for (C60). Install or Connect Blower motor resistor. Rearward mounting screw. Tighten Screw to 1.5 N.m (13 lb. in.) . Tighten both forward mounting screws. Tighten Screws to 1.5 N.m (13 lb. in.) . Electrical connectors to blower motor resistor. Right side instrument panel insulator.
Nov 22, 2008 at 10:04 AM
