1998 Pontiac Grand Prix engine swap
1998 PONTIAC GRAND PRIX
180,000 MILES • 6 CYL • FWD • AUTOMATIC
PTPBL3395
I recently put a 2001 3.1 buick century motor into a 1998 grand prix se and now the rpm gauge ,the tempurature gauge doesnt work and the car runs rough im reiceving error code p0107 the egr plugs dont match up do you have any suggestions?
Nov 19, 2008 at 3:25 AM
MASTERTECHTIM
  • 4,750 POSTS
was the grand prix the same size motor? 3.1j engine 3.1m engine or 3.1e engine. the eighth letter of the vin is the engine code. these problems you are having we should be able to fix them all but i need to know exact size engine to get p[roper wire diagrams. the tach is run through the ignition module and i would assume all 3.1 engines used the same ignition module so that is the first thing thats odd. the temp gauge is most likely a bad sender switch and can you swap the old egr valve into this engine? is it a electrical connector problem with egr or do the egr ports not match up?
Nov 19, 2008 at 6:23 AM
PTPBL3395
theengine i put in the grand prix was a 3.1j and the egr ports are different and so is the plug.
Nov 19, 2008 at 7:47 AM
MASTERTECHTIM
  • 4,750 POSTS
didnt the new engine come with a egr valve? if not then you will either have to swap intakes with the other engine or but a new valve and wiring connector, or get used ones from junk yard
Nov 21, 2008 at 6:09 AM
