1998 Pontiac Grand Prix engine knock
1998 PONTIAC GRAND PRIX
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOEMAC31501
I recently replaced the starter on a 98 pontiac grand prix gt. the old turned out not to be bad but was extremely loose. the next day the car developed a loud knocking soundin the motor. my intial thought was the starter i replaced it with was bad also and making contacting with the fly wheel. replaced it w/ old starter and problem continued. I checked the fly wheel and could not find any noticable cracks so that leads me to think maybe the engine has a broken rod. car cranks and still idles and has power in the motor however on acceleration the knocking speeds up also. the sound could be described as a wrech thrown in a metal bucket and shook. anyone have a guess what could be causing this problem. is there a simple way of telling if it is a rod? thanks.....
Aug 31, 2009 at 11:38 PM
MMPRINCE4000
  • 8,548 POSTS
Never use the "easy" word :) .
Drain engine oil into container, get a magnet and move around in the old oil, if you pick up metal particles, then you have a bearing problem.
If you find metal particles, remove oil pan, rotate each cylinder to BDC and grasp rod cap, if any movement, then rod bearing is bad.
Sep 3, 2009 at 7:00 AM
