1997 Pontiac Grand Prix Removing idler pulley
1997 PONTIAC GRAND PRIX
85,000 MILES • 6 CYL • FWD • AUTOMATIC
REBAL98
  • 4 POSTS
I am replacing the water pump on the above car. One bolt is blocked by the serpentine belt idler pulley. How do I get it off?
Thanks
Sep 18, 2008 at 3:30 PM
2CARPRO JACK
  • 11,533 POSTS
If it is an idler pulley it should have a bolt in the center of it. The tensioner pulley , you will probably have to remove the entire tensioner. Is this a 3.1 or a 3.8 liter engine?
Sep 18, 2008 at 7:14 PM
REBAL98
  • 4 POSTS
It is the idler pulley. There is a hole in the center. I can't make out whether it is a torx, alllen if anything. The engine is a 3.8 liter.
Thanks,
P.S. I'm not a complete novice. I've probably replaced 5 or 6 water pumps over the years. I've even replaced timing belts.
Sep 19, 2008 at 7:35 AM
2CARPRO JACK
  • 11,533 POSTS
Has to bolt on somehow, most likely a Torx, GM doesnt use many Allen bolts. Might even have a plastic cover over the center of it.
Sep 19, 2008 at 7:38 AM
REBAL98
  • 4 POSTS
Not much help. I'm back at square one.
Sep 19, 2008 at 9:22 AM
2CARPRO JACK
  • 11,533 POSTS
Has to bolt on somehow............ No software will tell what kind of bolts are used or how to remove some parts off an engine, they just assume that some things are abvious, so they dont go into details on how to remove them
Sep 19, 2008 at 10:01 AM
REBAL98
  • 4 POSTS
Ok from square one I looked it over again. I was wrong in my description. It's the power steering pump. How do I get it out of the way?
Sep 19, 2008 at 1:41 PM
2CARPRO JACK
  • 11,533 POSTS
Removal of that pulley requires a special puller as well as an installer to get it back on. You should be able to access the mounting bolts for the pump through the holes in the pulley and just unbolt it and move it out of the way
Sep 19, 2008 at 2:01 PM
