My car has been having higher temperature readings that are just shy of the red temp overheat stage. I checked the coolant levels and the overflow tank is just under half full. There is also good oil pressure. But I noticed that the radiator fans were not functioning. Is this the cause of my temperature problems? I would guess it would be the relay or the fans themselves are drawing to much amps causing them to knock out the relays, but what do you think about my problem?
Dec 16, 2008 at 3:35 PM
