1997 Pontiac Grand Prix NO spark
1997 PONTIAC GRAND PRIX
120,000 MILES • 6 CYL • FWD • MANUAL
SUEBELL
Was haviing problems with engine light coming on and it shutting off. like pulling off from a stop light, it would shut off. he would let it sit a minute and then it would start back up. then started surging. Changed fuel filter, getting plenty of fuel pressure now. but car will not start. it will turnover however. hooked up a engine code scanner and it did not come up with any errors.
Jul 1, 2008 at 6:43 AM
DOCFIXIT
  • 18,828 POSTS
Need to see if there is spark. Take a plug wire off get a plug put wire on it place plug on block have someone crank spary? blue?
If no check crankshaft sensor.
Let me know
Jul 1, 2008 at 7:31 AM
SUEBELL
Thank you for your help. We check for spark with the plug wire like you said and their is no spark. but he can hear the relay clicking.
Jul 1, 2008 at 6:54 PM
DOCFIXIT
  • 18,828 POSTS
Have crank and cam sensors checked you will need to have a scanner So you need to take it in to a shop.
Jul 2, 2008 at 7:34 AM
