1997 Pontiac Grand Prix Loss of fuel economy
1997 PONTIAC GRAND PRIX
150,000 MILES • 6 CYL • FWD • AUTOMATIC
BRANDI1975
I have experienced a significant loss of fuel economy. Egr valve is good, mass air flow is good, no fuel leaks, fuel pressure regulator is good, fuel pressure is good. Smoke tested and removed oil filler cap, found that the intake manifold was leaking.
Replaced intake gaskets, still no improvement on fuel economy.
Help!!!
Jan 21, 2009 at 2:54 PM
MMPRINCE4000
  • 8,548 POSTS
Are you getting any error codes?
Sensor failure will cause the engine to run rich, like coolant temp, TPS.
Have PCM scanned at any autoparts store for any error codes or pending codes, this is free.
Other possibilities are leaking injectors, Fuel pressure should not drop for 2-3 minutes after fuel pump is off, if it drops fast, most likely an injector or FPR.
Jan 22, 2009 at 10:13 AM
BRANDI1975
No codes, no pending codes, fuel pressure is good across the board
Jan 22, 2009 at 10:15 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuel pressure regulator vacuum line, if gas is present, then the FPR diaphram is ruptured and will need to be replaced.
If OK, then try to borrow/rent a scanner and hook up to car and go to live data mode, compare readings of all sensors to range limits.
Jan 24, 2009 at 9:05 AM
BRANDI1975
Have had it hooked to a scanner, but not sure about the FPR vacuum line, will have that checked...Thanks
Jan 24, 2009 at 9:46 AM
