1996 Pontiac Grand Prix Power Window - Drivers side
1996 PONTIAC GRAND PRIX
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
MPLEEGE
The driver's side power window will work and then stop working. Then you let it sit a little bit and it will work again. I checked the control plugs and theya re fine and the passenger window works fine(using the control on the drivers side. Any ideas?
Sep 5, 2009 at 6:00 AM
DEFIANTADP
  • 6 POSTS
I have the same problem with my 96 GP SE 2 dr. Mine used to be more apt to act up when it was cold or damp and it would work after I hit a bump or opened and shut the door. But now none of that helps. I believe its a bad window motor that has some loose wiring or is just tired. Hell its only 13 years old. I need to get her fixed before winter hits so I'm not out there fixing it in the cold. and Its really embarrassing to have such a good looking car but the window chooses not to work at the bank window or drive through resturant. Maybe we can get a discount if we both buy one together like 2 for one deal!
https://www.2carpros.com/forum/automotive_pictures/407635_96gpds_1.jpg
Sep 12, 2009 at 5:32 PM
