I have changed crank scensor, and the ignition control board that is located under the coil box where you plug in spark plug wires. the only way to open the fuel injectors is to ground out the main plug individualy the car will spit and sputter intill that gas is burnt out. then all it will do is turn over what else could it be
Jan 22, 2010 at 12:05 PM
