1995 Pontiac Grand Prix GTP Broke timing belt
1995 PONTIAC GRAND PRIX
162,000 MILES • 6 CYL • FWD • AUTOMATIC
WADETC
Is it likely that I've incured head damage when my timing belt broke / or is this an interferance engine?
Mar 1, 2009 at 4:23 PM
BRIAN 1
  • 1,030 POSTS
yes they are,these timing belts are a pain to replace,getting the timing marks lined up is a real pain in the butt.post back with any other questions.
Mar 1, 2009 at 6:01 PM
WADETC
but do the valves bend when the belt breaks?
Mar 1, 2009 at 9:54 PM
BRIAN 1
  • 1,030 POSTS
yes they do,because when the belt broke(I assume while you were driving) it will hang most of the valves open causing the piston on the up stroke to hit some of the valves,bending them.if you want to test if the valves are bent,you can 1 do a cylinder leak down test and listen for any air in the intake or exhaust or 2 remove the heads and check the valves.
Mar 2, 2009 at 5:31 PM
