I will attach the info from the manual below. However, I suspect you want to replace the switch because it is damaged or even you have the key stuck in it.
This was a common issue on these older GM products so here is a guide that will help with this:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
After running through the guide, the info from the manual is above.
Please let me know if you have other questions or need more info.
Thanks
Jan 27, 2022 at 5:18 PM
