1994 Grand Prix Ignition Problem?
I have the 3.4 DOHC motor. When i crank the car on a hot day, will not start. when left cooler for a bit (30 minutes) , the car runs, but does not drive far. The car will shut off while I'm driving. I thought Crank Position Sensor , but that should generate a Check Engine Light, which i don't get.
(Light bulb is working, check engine light does come on when another sensor is pulled)
(Didn't replace the Crank Pos Sensor)
My low coolant light is flashing a lot, but that's just the sensor i believe.. I check the coolant tank and there's plenty coolant.
I would guess fuel pump, but i poked the fuel line opening with a flat screwdriver and alot of fuel came out, alot to even put a tester on.
I'm not entirely sure what this problem is. You can hear the starter cranking, just no spark. Happens when the car is hot, just driving.
On a cooler day, i can drive the car all day with NO problems anywhere. starts up, drives all day. I drove for three hours straight nothing.
On a hot day, i wont get a half hour in before the car shuts off. No codes, hard to diagnose.
Any help or ideas would be appreciated Thank You!!
Jun 7, 2010 at 1:25 AM
