1994 Pontiac Grand Prix Electrical Issues??
1994 PONTIAC GRAND PRIX
170,000 MILES • 6 CYL • FWD • AUTOMATIC
ARB123
This car is having the following problems: Car randomly turns off while traveling and may or may not start back up, the speedometer is acting strange (ie. may show 100 mph when actually going 25), headlights flicker while traveling. The alternator was just replaced with a reconditioned unit, but didn't seem to correct the problem. Could it possibly be the battery? It's my daughters first car and I don't want her to get stranded somewhere!
Thank you!
Nov 18, 2008 at 10:05 AM
Hi:
Actually it seems more like a ground problem. Make sure that the terminals are clean and tight. Also, check the ground on the engine block and any body grounds you can find.
Let me know what you find.
Nov 18, 2008 at 12:04 PM
WATTS_AMAN
  • 15 POSTS
Besides your problem with the ground you may have to replace the battery after you fix the problem. This problem my be sucking the life outta the battery.
Nov 26, 2008 at 7:28 PM
