1994 Pontiac Grand Prix car stutters going up hills
1994 PONTIAC GRAND PRIX
187,000 MILES • 6 CYL • FWD • AUTOMATIC
PATTI0117
Ran fine, very good car with no burning of oil or any problems whatsoever. Then, blew a head gasket, which has been replaced. Put in new spark plugs, changed fuel filter. Ever since the car runs fine at a steady speed, even at 80 miles per hour. If, you are at bottom of a hill and not going fast then if you try to increase the speed it will stutter and shudder and totally bog down. any suggestions
Jul 17, 2009 at 12:43 PM
Check the listed components below and get back with some results
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 19, 2009 at 12:31 AM
MMPRINCE4000
  • 8,548 POSTS
I would start by checking the compression on the repaired head.
It may also be a valve problem, or clogged CAT, due to head gasket blowing.
Jul 19, 2009 at 8:09 AM
