1994 Pontiac Grand Prix Bleeding Brakes
1994 PONTIAC GRAND PRIX
124,000 MILES • 6 CYL • FWD • AUTOMATIC
MPRICE
We replaced a line on the right front wheel and now need to know in what sequence you need to bleed the brakes. We also replaced the rear brake pads and rotors. We bled the 2 back brakes, but still the peddle will go to the floor. We did not get any air out of the back brakes. What are we doing wrong?
Jan 22, 2008 at 9:18 AM
MERLIN2021
  • 17,250 POSTS
Open the bleed at the right front where you changed the hose. Let it gravity bleed untill you get fluid, then bleed the right front the normal way. Do not allow the Master to run dry! Use only DOT 3 brake fluid!
Mar 16, 2021 at 5:30 PM
