1992 Pontiac Grand Prix changing back 3 spark plugs
1992 PONTIAC GRAND PRIX
SURVEYOR777
Engine problem
1992 Pontiac Grand Prix 6 cyl Wheel Drive Type unknown Automatic 80000 miles
Can you help me in changing the back three spark plugs on this car ,I can not seem to see how to replace these spark plugs ,thanks .
Dec 20, 2007 at 12:08 PM
TOMMYES111222
[quote:83f2343e34="surveyor777"]Engine problem
Can you help me in changing the back three spark plugs on this car ,I can not seem to see how to replace these spark plugs ,thanks .[/quote:83f2343e34]
The 'dog bone' motor mounts are designed for this situation. There are 2 of these at the front of the engine compartment. They are cast aluminum with an extra hole. You'll need to take the bolts out at the engine side and pivot the mounts up and out of the way. Put the bolt back in the hole of the bracket only on the passenger side. Put a pry bar in the bracket pulling on the bolt to move the engine forward. You will need to put the bolt on the drivers side in the bracket, through the dog bone through the extra hole. This will give you room to get to the back plugs.
Dec 30, 2007 at 3:36 PM
