1991 Pontiac Grand Prix Running problems
1991 PONTIAC GRAND PRIX
154,000 MILES • 6 CYL • FWD • AUTOMATIC
JEREMEY123
The car will run but after a few seconds in gear it dies and doesnt want to start or run for awhile ? also when i put it in gear the engine mounts hit the hood, ive changed the engine mounts .
Dec 26, 2009 at 11:01 PM
To find out what's wrong check if its fuel or spark problem do below basic stuffs
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 26, 2009 at 11:44 PM
